It is currently Tue Jul 15, 2025 1:45 pm
 Post subject: wax over shellac
PostPosted: Tue Dec 24, 2013 4:48 pm
First name: george
Last Name: s
Does anyone have a favorite wax to recommend to put over a shellac finish? I want to put a final polish on a project. I have used McGuire's top coat safe before with some luck, but sometimes it clouds up. What do you use? Thanks,
GS
 Post subject: Re: wax over shellac
PostPosted: Wed Dec 25, 2013 2:22 am
First name: george
Last Name: s
Thanks Filippo. Are you using 100% carnauba, or a blend?. The hardware down the street has a carnauba blend in the wood finish aisle, but there was other stuff in there I did not recognize.
GS
Filippo Morelli wrote:
Depends. Carnauba or Briwax does the trick.
Filippo
PostPosted: Fri Dec 27, 2013 12:22 am
First name: george
Last Name: s
Fantastic, thanks. I'll look for it and give it a try.
GS
Carnauba can not be used at 100%. That's false marketing.
I use Zymol Carbon wax.
Filippo
PostPosted: Fri Dec 27, 2013 9:20 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I like Butchers Boston Polish, but any high quality furniture paste wax will do. Avoid bowling alley wax as it is not the right blend for this.
Brian
These users thanked the author B. Howard for the post: gxs (Fri Jan 03, 2014 12:58 am)
PostPosted: Fri Jan 03, 2014 12:59 am
First name: george
Last Name: s
Thanks Brian, I'll look for that also.
GS
PostPosted: Fri Jan 03, 2014 1:21 am
First name: george
Last Name: s
I found Johnson Wax general purpose paste did not work well for me, clouded up quickly. I also don't like that the JW doesn't say what is in it on the tin.
I also tried Howard's Feed -N- Wax, and while it was easy to work with I am not sure it left much of a wax coat over the shellac, which was already pretty shiny. Thanks guys, I'll pick up these products and give them a try.
GS
PostPosted: Fri Jan 03, 2014 5:10 pm
First name: Rick
Last Name: Turner
City: Santa Cruz
Zip/Postal Code: 95060
I keep meaning to get some Renaissance Wax...a "microcrystalline" wax originally developed for the British Museum. Suppose to be "da bomb".
These users thanked the author RTurner for the post: gxs (Sat Jan 04, 2014 6:27 pm)
